Hard starting when cold..
Old Dec 2, 2007 | 09:04 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
hi all
i started my Vette yesterday, behavior is the following...
outside temp is about 41°F...
i start, the engine coughs a bit, i give a bit throttle, the engine catches and run immediately..once the engine is just a bit warm, no more "start up" throttle is necessary
when its warm outside, the engine also starts immediately..
so i think, its just a small problem, which table in $8D i should look for?
engine is a 396 with 230/236XFI cam, SP EFI , 30#injectors and 10.8 to 1 comp.
this is, what my crank fuel pulse vs coolant temp look like
thank you
File Type: doc
Old Dec 2, 2007 | 09:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Hard starting when cold..
The IAC position plays a role in crank to start. May need to open it a little more.
RBob.
Old Dec 2, 2007 | 10:49 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
RBob.
Hi and thank you
my dumb queston now: how can i do this?
my IAC counts are pinned at 160 counts when my engine is idling cold...and, AFAIK more than 160 is not possible...when hot, IAC is about 60 counts idling
thank you
Old Dec 2, 2007 | 01:05 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Readjust the IAC per this article. If your normal idle speed is higher (due to modifications), set the IAC idle speed to 50-100 rpm less than your normal "full warmed up" idle speed. The idle speed for the IAC is the article is for a "stock engine" and too low for a modified engine.
https://www.thirdgen.org/tpimod2
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
