proportional counts on 7427 ecm
Old Dec 12, 2007 | 08:22 AM
getsideways's Avatar
i cant get rid of this surging at low map cruise/decel. afr swinging on wideband from 12.0-17.0. have reduced prop gains vs. rpm vs. map table by almost 4x stock. but what is the function of prop counts vs. o2 error? do i need to reduce these numbers to reduce the surge? i guess i dont understand what that table does.
thanks.
Old Dec 12, 2007 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: proportional counts on 7427 ecm
Proportional gains force the AFR to oscillate. This is for the cat-con to function properly. Make sure that the INT is holding steady. If not then the prop gains, duration, INT delays, and O2 error values need to be worked on.
RBob.
Old Dec 12, 2007 | 01:04 PM
can you explain what the prop counts vs o2 error table does? what happens if i put smaller numbers in this table? and what does 6375 msec in the prop duration tables mean? thanks
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
