now have wideband what is ideal????
Old Dec 18, 2007 | 10:18 AM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
Got the wide band in place and car drives good around town but is wicked lean at wot and looking for what are the ideal afrs for wot and driving. 12.5 for wot and 14.0 for driving is what I have been told. I know that wot will be what the car likes wot make most power as I have seen it with many cars making most at 12.5 and some do better rich for some reason at 11.5 like my buddies carbed mustang. I know efi and carb also seem to like different afrs too. Never have tuned by afr before just blm and seat of the pants and seat of the pants got me know where last weekend at the track because it is showing 17.1 on the afr and plugs didnt look that lean. Also I know the formula for changing the ve tables when going off the blm being above or below 128 multiply the divide by the table. Is there a formula for the afrs in reference to the table to do the same thing. To get it at 128 128 .
Old Dec 18, 2007 | 11:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: now have wideband what is ideal????
You mention pump gas, if this is less then 10% ethanol, then 12.5 is a safe AFR. For the engine at least. If there are cat's on the car then you need to plunge to 11.0 area in the midrange RPM to put them out.
RBob.
Old Dec 18, 2007 | 02:27 PM
lt1z350's Avatar
no cats on the car. How about driving around for best gas mileage with no lean miss?
Old Dec 18, 2007 | 03:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This varies according to load and engine. Generally in the 16.0 to 16.6 AFR range. Also need to add SA timing. I have a few posts on lean cruise. If they can be found it would help fill in this info.
RBob.
Old Dec 18, 2007 | 04:41 PM
Ronny's Avatar
is the WB calibrated to fresh air?
Old Dec 18, 2007 | 05:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i've heard 12.8 to 1 for n/a performance at WOT, atleast in the upper rpm range
Old Dec 19, 2007 | 09:52 AM
Ronny's Avatar
You need to test for max MPH over a set distance. A start at 10 MPH may be best so that traction at launch is reduced.
InfernalVortex
Apr 20, 2021 11:31 AM
efiguy
Sep 27, 2015 01:30 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
tuningnewb
Sep 23, 2015 07:06 PM
BWilcox
Sep 20, 2015 12:19 PM
