0D mask, wheres IAC settings?
Car: 96 S-10 Blazer
Engine: 355 TBI
Hey guys,
Ive begun doing my own programming and so far its going good. But before i start working on the performance I have one more drivablity problem to work out which is with the IAC. It stays way open, my truck will idle at around 1100rpms in park and 900-1000 in drive. The data logs are showing its staying open at about 80-100 steps.
My setup is a TBI 355 with a BBC TBI unit and IAC. The rewiring for a BBC IAC seems to be working because the IAC will retract and close in the 80-100 steps range... Im using a 16168625 ecm with the $0D mask.
The problem is in my XDF file for tuner pro, i cant find anything in there that has to do with controlling the IAC steps! Im using the 0D v1_02.xdf file on Moates' web server.. Is there a better XDF i can use or what?
Thanks, andy
Thanks, andy
