BLM/INT usec equivalents??
Old Jan 18, 2008 | 08:57 AM
91chevz71's Avatar
I was wondering how much 1 unit of Integrator change and 1 unit of Block Learn Mult change is, in fuel. It's probably got a lot to do with BPC and injector size.??
Just wondering how the computer reflects the change in BLM/INT at the injectors.
Old Jan 18, 2008 | 09:56 AM
Ronny's Avatar
Re: BLM/INT usec equivalents??
something tells me it may be fuel pressure related as well. some where in cyberspace is a formula....
Old Jan 18, 2008 | 12:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
How the INT & BLM modify the PW varies with the ECM mask. Some just add/subtract the value, others will use it along with the current PW as a modifier.
On the EBL the BLM value will add/subtract 15.26 usec from the PW per unit. So 130 will be 2 units (130 - 128) for 30.5 usec added to the PW. This is done early on with the PW being further modified by DE, DFCO, and battery voltage compensation. Which are multipliers to the PW, which at this time the BLM is part of.
On the EBL the INT is easier. It a straight add/subtract of 15.26 usec per unit. No further modifications.
The proportional gain is the same as the INT. It will be added/subtracted to the PW late with no further modifications to it.
RBob.
Old Jan 18, 2008 | 12:13 PM
91chevz71's Avatar
excellent, thanks Rbob
Old Jan 18, 2008 | 12:43 PM
Ronny's Avatar
would this allow you to calc the exact amount of fuel delivered?
http://www.users.bigpond.net.au/ben_...ctorsizing.xls
64goatman
Sep 9, 2015 01:09 PM
tmellott89
Aug 16, 2015 02:58 PM
funstick
Sep 28, 2002 11:59 PM
V8Astro Captain
Sep 26, 2002 08:43 AM
JPrevost
Nov 30, 2001 08:26 AM
