disconnecting IAC
Old Feb 2, 2008 | 11:44 AM
NatesL98's Avatar
Car: 1990 Iroc-Z
disconnecting IAC
WIll disconnecting the iac make my idle high. i still have a high idle even after replacing my iac. trying to figure if its vac leak or what.
Old Feb 2, 2008 | 11:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: disconnecting IAC
Depends upon where the IAC is when disconnected. Can close it first then disconnect it. To close, short A & B on the ALDL connector, then key-on, engine-off. Wait about 15 seconds then disconnect the IAC. Key-off, remove jumper.
RBob.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
