nuetral saftey switch question on mega shifter
Old Feb 5, 2008 | 09:32 PM
tjvz28's Avatar
Car: 91 Camaro Z28
hello i put mega shifter in a while back and it called for switch from radio shack and i hooked every thing up right and every 50 starts or so i fry the switch and the car wont start then i hard wire it to start and then the car will sometimes die when i put it in gear untill i replace the switch is there a way to get rid of this when im burning my chip thanks
Old Feb 6, 2008 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: nuetral saftey switch question on mega shifter
No, no way to bypass the neutral safety switch in the PROM. That switch also carries quite a bit of current. It is the ignition switch crank feed to the starter solenoid. Best bet is to get the proper switch or a larger one from RS.
RBob.
Old Feb 6, 2008 | 07:37 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Wire in a relay if its too much current for that switch.
colton_carlson
Mar 8, 2019 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
