S_AUJPV4 Question, O2 sensor, wiring into ECM??
Old Feb 18, 2008 | 10:14 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Greetings, I've been using V4 and the next thing to do is get the WB 02 sensor. So I'm reading the following in the documentation:
6.) Wide Band Multi-Sensor Support (Thanks to Don Dibble, 1981TTA)
Selectable sensor and calibrations incorporated by Scott Lopez Z69’
Made ALDL word 37 = 0035 to monitor WBAFR (OEM = 002D Was “Keep Alive IAC Steps”)
COPYRIGHT MATERIAL
******** Calibration Section *************
2000: .byte 0x00 ;set default sensor option here.
Option Flag for WB O2 Sensor,
Bit 0 = DIY_TE NonLinear
Bit 1 = FJO
Bit 2 = AEM NonLinear
Bit 3 = TE 2.0 Linear
Bit 4 = PLXWBLin
Bit 5 = Innovate Linear
Bit 6 = AEM Linear
2001: .byte 0x00 ;set default sensor option here.
Option Flag 2 for WB O2 Sensor
Bit 0 = RAW A/D Output
Bit 1 = Innovate Linear L2H2 (vdc*2+10)
Bit 2 =
Bit 3 =
Bit 4 =
Bit 5 =
Bit 6 =
Bit 7 = Zeitronix
Bit 7 = Select WB Input
(0) = Pin F14
(1) = Pin A3
Select ONLY 1 Sensor type or the “Raw Output”
(See XDF description below for adding this item with your definition editor)
Is there any more guidance on hooking up a WB02 sensor? From what I can figure is that you set ONE in location 2000, and set ONE in location 2001. I figure that I can do that, but how do I know where to wire the sensor into the ECM?
Old Feb 18, 2008 | 06:43 PM
Axle/Gears: 4.1
And, as long as I'm asking questions...
When I look at my spreadsheet I noticed a column titled as follows:
Calc'd VE
VE %
Can anyone tell me what this column represents?
Old Feb 18, 2008 | 07:16 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: S_AUJPV4 Question, O2 sensor, wiring into ECM??
Bit 2 =
Bit 3 =
Bit 4 =
Bit 5 =
Bit 6 =
Bit 7 = Zeitronix
(0) = Pin F14
(1) = Pin A3
...but how do I know where to wire the sensor into the ECM?
2001:
(0) = Pin F14
(1) = Pin A3
Calculated VE% was added to the datastream.
It is the calculated value the ECM is using.
The MAF guys were lucky enough to have it by default, I replaced the PROM ID in the datastream (Which is useless) to have the value displayed.
Its just another reference data for figuring out what is going on.
HTH
Jp
Old Feb 18, 2008 | 10:19 PM
Axle/Gears: 4.1
so, let's say I got the Innovate WB02, then I would wire it in at Pin F-14 and Pin A-3, Set the flag at Bit 5 in the first section and Bits 1 & 7 in the second section? (the ones shown below).
(0) = Pin F14
(1) = Pin A3
Following up on the %VE question, and I hope this isn't overly simple, but "percent" of what?
Old Feb 19, 2008 | 12:00 AM
JP86SS's Avatar
The pin you wire to is selectable by bit 7.
If you wire to F14, the bit is NOT set.
If you wire into A3 then the bit is set.
Only one or the other is used. (F14 or A3)
Same with the selection of the sensor type.
Turn the bit on to select the one you have or use the "raw" option.
Jp
Old Feb 19, 2008 | 08:12 AM
Axle/Gears: 4.1
SO, are the following 2 different Innovate WBO2 units? Or is it the same WBO2 unit that needs to have 2 bits set (well, + the A3 connection)
I'm a little confused and have to decide which WBO2 to purchase. I don't see much discussion on a preferred brand.
$750 L98
Feb 1, 2025 02:25 PM
meeklay812
Oct 1, 2015 03:46 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
sylentnite
Sep 9, 2015 02:55 PM
Ironhead38
Sep 7, 2015 02:26 PM
