files needed please 6299 ecm
Old Feb 28, 2008 | 10:25 PM
madzx2's Avatar
if anyone has the definition file for the 6299 could i please get it or can you let me know where to find it. im using tunerpro rt.
Old Mar 4, 2008 | 07:32 AM
madzx2's Avatar
Re: files needed please 6299 ecm
no one has ever tuned this ecm?
Old Mar 4, 2008 | 11:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is a good possibility no one has. The '6299 is not that popular of an ECM and was never used in a '82 - '92 Camaro or Firebird. You may be able to change it out for a '7747 or '8746 ECM. This may also entail changing a few ECM harness connector pins around. The '7747 & '8746 are well known in these parts.
RBob.
Old Mar 5, 2008 | 06:45 AM
madzx2's Avatar
do you know if the 7747 is a direct swap? ive read it is but would like to know for sure. thanks.
Old Mar 5, 2008 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It may or may not be a direct swap. Within this family of ECMs 99% of the pins are dedicated. For those pins they will be the same between all ECMs (within this family).
Where they can change is some of the quad driver outputs and some of the status inputs. You would need to compare your wiring against the '7747 wiring. You may find that they all match up and it is a direct swap. You may find that 2 pins (or more) are reversed and need to be changed in the harness connector.
RBob.
Old Mar 5, 2008 | 06:56 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have, but I didn't get out of town to grab the laptop it is on this past weekend.
Old Mar 20, 2008 | 09:28 AM
madzx2's Avatar
so i know fast has the files but know one else has ever dealt with this ecm? im still patiently waiting for the files from fast but would like to get started asap.
Old Mar 29, 2008 | 06:31 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
im getting ready to start playing with mine too... did you ever come up with the file?
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
djmarch
Aug 10, 2015 08:42 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
