reading a hack
Old Mar 4, 2008 | 07:55 AM
getsideways's Avatar
reading a hack
im trying to understand the lingo in the hack so i can decifer how to get my $0D bin to stay in open loop idle. here is some of the hack
; MPH and TPS within limits to be idling, check quals for open loop idle
BSET L0050,#$80 ;Status word, set b7, idling
LDAA L0295 ;Open loop idle AFR
CMPA L026D ;Compare to stored AFR
BHI L8AFC ;Bra if AFR < open loop idle AFR, disable
;open loop idle
;-AFR is less then lean idle AFR limit here, enter open loop idle
LDAB L0006 ;Cool temp, linearized
CMPB L48D8 ;Threshold to remain in open loop idle
BLS L8AE9 ;Bra if less, remain in open loop idle
LDAB L48D4 ;Timer threshold to enable open loop idle
BEQ L8AC9 ;Bra if ==0, check INT thresholds
LDX #L400B ;Opt. byte
BRSET 0,X,#$02,L8AB0 ;Bra if b1==1, AIR enabled
;-No open loop idle in P/N if AIR not optioned
BRSET L0041,#$20,L8AFC ;Status word, bra if b5==1,in park/neutral
;-Here if AIR is enabled or in drive
L8AB0 BRCLR L0050,#$02,L8AC1 ;Status word, bra if not in open loop idle
; In open loop idle
LDAB L0294 ;Idle timer
CMPB L48D5 ;Timer threshold to transition to open loop idle AFR
BLS L8AD9 ;Bra if timer <=, increment timer and cont.
;-Here to use open loop idle AFR
LDAA L0295 ;Load open loop idle AFR
BRA L8B05 ;Bra to continue
; Not in open loop idle, check quals to enter
L8AC1 LDAB L48D4 ;Timer threshold to enable open loop idle
CMPB L0294 ;Idle timer
BCC L8AD9 ;Bra if timer is <=, dont allow open loop idle yet
;-Check INT thresholds for open loop idle
L8AC9 LDAB #128 ;Neutral INT value
LDAA L0232 ;INT
CMPA #128 ;Compare to neutral value
BCC L8AD3 ;Bra if adding fuel
;-Fueling is leaning out
NEGA ;Negate INT
L8AD3 ABA ;Sub out neutral INT to get diff. from neutral val.
CMPA L48EE ;Delta INT threshold to bar open loop idle
BLS L8AE4 ;Bra if delta INT is less
;-INT threshold not yet met for open loop idle and AIR
L8AD9 LDAB L0002 ;Loop counter
CMPB #$27 ;Counter val to update timer
BNE L8B02 ;Bra if !=
INC L0294 ;+1, idle timer
BRA L8B02 ;Bra to continue
; Here to enable open loop idle
L8AE4 BSET L0050,#$02 ;Status word, set b1, open loop idle
BRA L8AFF ;Bra to continue
;-Alternate entry point if not resetting idle timer
L8AE9 BSET L0050,#$02 ;Status word, set b1, open loop idle
; Here if not idling
L8AEE LDD L00F8 ;Engine run time
CPD L48D6 ;Engine run time to clear initial idle terms
BCS L8AF9 ;Bra if timer is <
BSET L003F,#$40 ;Status word, set b6, clear initial added IAC flow
L8AF9 BCLR L0050,#$80 ;Status word, clear b7, idle flag
;-Here to disable open loop idle
L8AFC BCLR L0050,#$02 ;Clear open loop idle flag
L8AFF CLR L0294 ;Clear idle timer
L8B02 LDAA L026D ;Stored AFR
L8B05 BRSET L003E,#$80,L8B3F ;Status word, bra if b7==1, in closed loop
; In open loop here
BRCLR L0004,#$10,L8B13 ;Status word, bra if b4==0, no hot restart
;-Hot restart in effect
SUBA L4952 ;Subtract AFR bias for hot restart
BCC L8B13 ;Bra if no underflow
CLRA ;Clear underflow
;-Hot restart not in effect, check temp limits for open loop AFR enrichment
so what does "bra if" statements mean? also when i see the word threshhold. does the value need to be higher to enable?
;-Open loop idle quals
L48D4 FCB 255 ;255 sec, timer threshold to enable open loop idle
L48D5 FCB 0 ;Timer threshold to remain in open loop idle
L48D6 FDB 0015 ;15 sec, time after startup to clear initial idle terms
L48D8 FCB 100 ;35 dec C, threshold to remain in open loop idle
;-Open loop AFR params
L48D9 FCB 173 ;90 deg C, temp threshold for open loop idle AFR bias
L48DA FCB 0 ;-40 deg C, lower cool temp for open loop AFR enrichment
L48DB FCB 254 ;151 dec C, upper cool temp for open loop AFR enrichment
L48DC FCB 200 ;10 secs, time limit for initial AFR enrichment
L48DD FCB 147 ;14.7:1, stoich AFR
L48DE FCB 16 ;1.6:1 AFR bias for open loop idle
; Used prior to TPS action after start up
L48DF FCB 147 ;14.7:1 AFR, lower limit for quasi-closed loop
L48E0 FCB 10 ;1.0:1, onitiial AFR enrichemnt
L48E1 FCB 5 ;0.5:1, initial AFR enrichment if in park/neutral
L48E2 FCB 6 ;Filter coeff. for filtering AFR after transition from idle
Old Mar 4, 2008 | 05:19 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: reading a hack
BR "Branch" statements work like this for example:
BRSET if the statement is true, then BRanch to location L8AFC
The statement is: is the bit at location L0041 bit 5 turned on?
L0041 is the address, # states its a number not a value, $20 is hex for bit 5.
Syntax does change in some cases between assemblers/disassemblers so you'll need to be careful determining if something is a value or an address.
The text after all this is from the author telling you that "branch if L0041, bit 5 is ON" (Park or Neutral position will make that true)
Thresholds are just values that must be crossed to make something true/false. Can be high or low depending on what you are doing.
HTH
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
gta892000
Sep 16, 2015 12:40 AM
WickedBowtie
Sep 11, 2015 11:24 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
