Cold Afr?? Tbi
Old Mar 14, 2008 | 01:31 PM
90c350's Avatar
Cold Afr?? Tbi
Hey guys just wondering what is a good AFR for a cold engine first start up and after choke has come of?? Just put my WBo2 in and Im getting about 11/12 Afr when cold. But when I puut it into Drive or reverse the Afr will drop to like 10/9 Afr. This will cause it to stall out do to being to rich sometimes. Its a 7747 Tbi $42mask with some mild mods etc. Im just wondering if I should reduce the Cold Map adder table in the higher Map ranges. When in closed loop its fine. I can tell that when at an idle or engaging a higher map it will go pig rich for a second or 2. Any thoughts or help would be great thanks
Old Mar 14, 2008 | 09:41 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Re: Cold Afr?? Tbi
With my EBl tbi motor, I had the O/L afr tabl at like 10.2 at the low cts values. I had to up it to high 11's. This worked for me. I have a heated, but the c/l timer is set for like58degree c I think, then it is 14.7.
may try leaning it out a bit and see how it runs. if you go to close to 14.7, it most likely won't like it, as engines like a richer afr while still cold. how much varies from engine to engine though. hope this helps
Bubbajones_ya
Jul 6, 2024 08:32 PM
hydrolic144
Sep 8, 2015 06:59 PM
scottmoyer
Sep 7, 2015 07:06 PM
lakeffect2
Sep 7, 2015 03:52 PM
dimented24x7
Sep 6, 2015 03:51 PM
