PW for 80# inj at 18.5 psi
ok today i finally got to see my pw and noticed...that ...at 5k cuase winaldl is so slow..that my pw is 5.8ms is that not static and if so..how low do i need to be and how do i figure out actually duty cycle of it..
note setup is tbi with 2 80# injectors at 18.5 psi bpw is 88....
Car: check
Engine: check
Transmission: check
Re: PW for 80# inj at 18.5 psi
The Tuning Issue thread that you have been posting to on the TBI board has the injector static PW information in it. I have a post that explains it along with the math, while MonteSS posted a chart of PW vs RPM of when the injectors are at 100%.
https://www.thirdgen.org/forums/tbi/...ing-issue.html
RBob.
RBob.
