P/N Switch and IAC
Old Apr 1, 2008 | 06:51 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
P/N Switch and IAC
If you don't have one conected to
your ECM, will it cause some start up
problems 730 8d
Old Apr 1, 2008 | 07:31 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Re: P/N Switch and IAC
If you have an automatic trans you might experience stalling issues when shifting from p to r or p to d without a p/n switch. Also if the ecm thinks your in p when your pulling up to a stop sign you may have some stalling problems. With a manual trans none of that is a problem. The IAC valve, in my opinion, is a must have to get the engine started in real cold weather.
Old Apr 1, 2008 | 08:46 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
I have the IAC but p/n switch is not
pluged in to the ecm. 700r4 trans
so the ecm can't tell if i'm in park or drive
Old Apr 1, 2008 | 09:03 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Does the ECM think the car is in drive
all the time
Old Apr 1, 2008 | 09:42 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Both of my TPI vehicles are manual so i never tried it but the p/n switch conects to ground in gear so without it the ecm thinks your in p. Try connecting the circuit full time to ground and seee how things go idle wise.
Old Apr 2, 2008 | 01:31 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Anyone ever tried this, if so, did it fix any idle problems
Old Apr 3, 2008 | 12:17 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i don't have the P/N switch hooked up in my car & i have no problems. it thinks its always in gear.
i did have it hooked up for a few days, i didn't like the surge i got when i shifted from park into gear so i unhooked it.
Old Apr 3, 2008 | 12:24 PM
84KYSS's Avatar
Car: 84 Monte Carlo SS
Engine: 408
Transmission: 700-r4
I don't think the P/N switch is your startup problem. Mine hasn't been hooked up and hasn't been a problem. In my last eprom burn I zero'd out the startup spark advance. Then I changed the coolant temp correction table to give around 5* SA at 20-45 degress and lower, 7* when colder. This is similar to what GM did in the ARAP calibration. My closed throttle SA and 100 kpa column below 1600 rpms is 26.02. When I went to crank the car it didn't fire right away. I had to open the throttle a little and then it fired. I think it was getting too much advance while cranking because until I made those changes it always started on the first turn of the key after a few revolutions. My initial is 10* BTDC which is what I have in the chip. What kind of timing are you using for colder starts?
Old Apr 3, 2008 | 01:34 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Long crank times and 160 IAC steps when cold. My 100kpa column is
23.02. The iac steps when warm would go to 0 when it is fully warmed
up and would make the idle high. I set the idle like this so it wouldn't
die at open loop and cold temps. Spark is around 30-32 degrees cold.
Timed my car to 6 degrees and have that in the chip
Old Apr 3, 2008 | 08:43 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
884+3 a few posts up says it's in park, you say in gear, what is it in park or in gear
Old Apr 3, 2008 | 10:20 PM
DENN_SHAH's Avatar
i believe it shows different with some of the other bin files.
IIRC, i have read on this site that the standard bins shows
in gear with it hooked to ground.
im running AUJP & for me unhooked shows to be in gear.
which bin are you running?
Old Apr 3, 2008 | 11:00 PM
shuanm's Avatar
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have a standard shift and I was wondering if I should connect the P/N to ground or not. Maybe that would solve the problems I'm having. I am using a VSS and my EGR is blocked and turned off in my program.
Old Apr 4, 2008 | 09:25 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Yes I'am running AUJP also so i'm in gear then.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
greenyone
Sep 8, 2015 08:41 PM
luvofjah
Sep 3, 2015 07:08 PM
greenyone
Sep 2, 2015 03:39 PM
