part throttle driveability issues
Old Apr 14, 2008 | 01:23 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Hi all
took my car for a ride yesterday, and it still seems, that i have to do some fine tuning...
the engine is a 396 with 195elim.heads, single plane, and XFI467 cam,
6 speed...
when i start cold, i usually have to give a bit gas, so that the engine wants to start....
when driving with cold engine, it doesnt really run that smooth...
when the engine is warm, and i cruise with 4th gear at about 2000-3000 rpm everything ok, but when i step on the gas, i get some kind of strange vibration, that disappears when i let of the gas..
i donīt run a very aggresive spark table, and also the AE is fine, as the engine takes gas like it should...
i run 95octane (european), thats equal to your 91 octane...
can you point me in a direction?
thank you
Reinhold
Old Apr 14, 2008 | 09:43 AM
90c350's Avatar
Re: part throttle driveability issues
What kind of Induction are you running TBI or Carb?
Old Apr 14, 2008 | 12:33 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
hi
iīm running a single plane EFI intake with a ī727 ECM
thank you
Old Apr 14, 2008 | 01:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Is the TB facing forward on an elbow? If so try a TB that faces the standard 'toward the sky' position. IIRC, antheses had an issue with the elbow setup. There is a thread about it here on diy_prom.
RBob.
Old Apr 14, 2008 | 01:30 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I'm running 165 w/maf so I don't know if this pertains to your system but... I had a simular problem and found that is was too much fuel and timing. Mine was doing it in the 1500 rpm range. Hope it helps.
Old Apr 14, 2008 | 03:26 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
RBob.
Hi
yes, its an elbow style...i will do a search, hope i find it...
thank you
hi
that is what i was thinking, too...VE not right, and spark not right...i will do some datalogs and see, what come out
otherwise. at higher rpm the engine really runs fine, no noises, etc...
Generally: i would not say, my combination is that radical, is it?
thank you
Azrael91966669
25
Jun 20, 2017 04:04 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
mdtoren
Aug 16, 2015 05:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
