Small cam
Small cam
Hey i have a stock 350 with a 90-92 camaro map using SAUJPV4. If I put in the cam from summit part # sum-1104 duration 282/282, lift .465/.465. I was wondering if i should adjust anything in the bin for this new cam or leave things as they are? I dont have many chips to spare thats why i am asking prior to tinkering. Any advice would help! I am new to programming/tpi.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Small cam
That cam is all wrong for a TPI engine. Look for a cam that makes power in the idle-5,000 rpm range, has a 112* LSA, and has decent lift. No sense in adding a cam that is just starting to come on hard as the TPI falls off a cliff.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Small cam
Try it but if the tuning gets too hard then maybe a change will help. Consider changing intake to mini ram or something that runs in the higher rpm range. Hope you have 4:11 gears in that beast. Watch your vacuum for the brakes. That cam is around a 2200-5200 rpm cam with a narrow, high peak, torque and HP. It would make a good six speed cam. Call comp cams and just see what they recommend for your setup.
Re: Small cam
Ok so this is the plan. I have a 1227730 ECM and I plan on getting a ERPOM from a fbody 350 90-92. I am thinking of getting a autoprom and 2-3 chips. Any downfalls or am i missing anything?
and i think i need a g1 adapter?
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
