7747 XDF file
7747 XDF file
Hi all,
I pulled the XDF file from Tunercat and the ve table from it is different from CATS tuner main fuel table #1 VE.
Did I pull the wrong XDF file? where can I find the correct one?
Car: check
Engine: check
Transmission: check
Re: 7747 XDF file
The VE table is pivoted? Or missing a row or column. Common issue that dates back 10 years or more.
Don't know where to find a correct version. However, the pictures show the proper values for the XDF along with the proper table layout. In tuner Pro highlight the VE #1 table entry, right click, then select edit XDF item.
Then change the row & col tabs values to match what is shown. Save the XDF.
RBob.
RBob.
