COLD FUELING address ??
Car: 1982,Z/28
Engine: 355
Transmission: t350
I want to adjust my cold fueling in my bin, and i always read where it says adjust the A.F.R. , V.S C.T.S TABLE ? ----- The only thing ive been able to find is , O/L A.F.R. VS TEMP,? -- And it has a address of 045A, in tuner pro, with a 7747 ecm. ---Is this the same correct one to adjust for cold afr adjustment ??
Car: check
Engine: check
Transmission: check
Re: COLD FUELING address ??
For open loop AFR there are two tables used. One is vs vacuum, the other is vs CTS. The one you listed at $45A is the CTS based AFR value.
The vacuum based table is at $41E
The code does a lookup on each table and adds the values together. The result being the commanded open loop AFR (along with after start adjustment if any).
RBob.
RBob.
Car: 1982,Z/28
Engine: 355
Transmission: t350
Thanks Rbob, The reason im asking is i want to lean out my cold fueling as when its cold, and you attempt to give it gas it falls on it face, with to much fuel [you have to feather the gas on accell when cold to avoid it] ----- Also if i put my pump shot at stock settings it does not do this, but then im lean on accell when its warmed up and get lean back fire in intake.---So i was aiming at cold fueling [choke] ????? -- Im a crossfire, working off the asdz bin .
Car: 1982,Z/28
Engine: 355
Transmission: t350
heres what i got,- When veh is warmed up, it has a pop thru intake [wide ban showed this lean] last year when it worked ! --- But when veh is cold, has a major rich condition if you get on the gas. [have to feather the gas] I can even stall it with too much fuel on accelleration. ??. Ive raised the pump shot up [map/tps, to get rid of lean condition which helped some ??, BUT IF i leave it at stock setting, [asdz bin] the accelleration flooding goes away ???, Im just lost as to what to change in the bin to possably remedy this. - Ive leaned out my cold fueling, and it had no affect.
