Idle Issue, please read.
Old Apr 30, 2008 | 08:03 PM
VetteC5RFrEak's Avatar
Car: 1989 Camaro RS (w/Z28 tags)
Engine: 305CID TBI
Transmission: Manual - T-5
Axle/Gears: Stock
I have a thread going in the TBI Tech Boards that I started over a year ago. I posed a question that RF Master told me I should pose in here, so here it is.
Originally Posted by ME
My car has somewhere near or over 300,000 miles on it. The engine is not the original engine. The heads, intake, and TB are the only original parts of the engine itself. The block is a '77 305 block because the previous owner ran the engine with pretty much no oil. Anyways, that means if the TB is the original one from the factory, which I have no doubts why it wouldn't be, then the TB is probably due for a freshen up. I doubt that TB was ever serviced. I was watching the spray pattern from the injectors and pretty much it is a mist. However, if you look closely, it appears there are small driplets from the center of the injector dropping into the bore. Now this is where I have come up with a speculation, and you can let me know how close or far off this speculation might be:
If the injector is dripping extra fuel into the engine, the ECU would have to compensate for that by opening up the IAC so the engine isn't running rich, this in turn would raise the idle. The injectors might only leak extra fuel when opened more then what they are at idle. So when I tap the throttle, it opens the injector up and squirts the fuel in to raise the rpm's, but when I let off the throttle, the injector has now been opened and extra fuel can leak out which would cause the IAC to stay open so the engine doesn't run real rich. When the car is up 3 mph the ECU kicks the idle up to help with shifting, well, if the scenario I just described is true, it would exaggerate that kicked up idle since the ECU is opening up the injector.
What do you guys think, is this scenario plausible? I have tried every sensor on the engine, I have searched and searched for vacuum leaks, I can't come up with anything.
Here is the original thread to get some more background information:
https://www.thirdgen.org/forums/tbi/...ng-issues.html
Old May 1, 2008 | 12:45 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: Idle Issue, please read.
Have you ever datalogged it to see what the iac counts are? I guess it would be possible for that to happen if the pulse width at idle is set at xx and the o2 sensor detects a rich mixture. If the iac valve is actually opening up a dataloge would show it.
Dewayne
Old May 1, 2008 | 01:48 AM
Engine: 305CID TBI
Axle/Gears: Stock
Yea, I have had the car hooked up to a GM Tech 2 at school and it is showing like 10-12 counts for the IAC when at idle (600-700 rpms). But I do notice the pentacle likes to hang open if you blip the throttle, which makes me think that the injector leaking might just be the culprit.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
