deaccelleration pop and jerking
Old May 17, 2008 | 08:24 AM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I just gutted my cat and added a catback. Now sometimes when I let off the gas after some RPMs I get a pop or a backfire. Would this be consistant with a lean condition? If so whats the first step to tracking this down?
Old May 20, 2008 | 08:46 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
Re: deaccelleration pop and jerking
I get the same thing, pretty sure I am running rich
Ryan
Old May 21, 2008 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Most likely an exhaust leak.
RBob.
Old May 22, 2008 | 10:01 AM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Is this pop or backfire in the exhaust? If yes, I would have to say raw fuel in the exhaust when you let of the loud pedal. It is being lit by the hot pipes. I have seen mufflers blown apart this way.
Old May 22, 2008 | 11:20 AM
???'s Avatar
if your smog pump is still hooked up blowing air into the exhaust it will cause that. if not, exhaust leak.
Old May 22, 2008 | 11:23 AM
SDalt404's Avatar
Car: 1988 GTA
My smog pump is definately still hooked up.
Old May 22, 2008 | 11:30 AM
???'s Avatar
time to by pass it if you don't have cats. there may be a way to change stuff in the chip so that its in its vented to the outside air mode all the time. but I wouldn't have a clue how.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
