What prevents us from using a 3 bar MAP with a 7730 ECM?
Old May 28, 2008 | 10:51 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
I don't understand why we can't use a 3 bar MAP to tune for boost with a 7730 ECM. You can add columns to the tables using the XDF editor feature of Tuner Pro, so you should be able to add KPA all the way out to 300 and then use a 3 bar MAP sensor. You'd have to dink with it some to see what voltage corresponded to 1 atmosphere, then set the table up accordingly, but I would think it would be pretty easy to extrapolate the values.
Why won't that work? What gives?
Old May 28, 2008 | 11:48 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: What prevents us from using a 3 bar MAP with a 7730 ECM?
you can use a 3 bar on a 7730 ECM, you just need to repin it & change the code.
http://code59.org/
Old May 29, 2008 | 12:01 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I think there are alot of tables and things that you dont find in the xdf file that needs to be changed. If it was easy I'm sure it would have been done already, The 8D boost issue has a long history here on thirdgen, and from what I know there is only one guy who runs a 8D. code made for boost, its not public yet and he did all the programming by himself.
/N.
Old May 29, 2008 | 06:54 AM
ty1295's Avatar
Adding columns in tunerpro won't do anything for the real code behind it. Isn't that easy.
Think of tunerpro as a road map. You can draw new lines of roads you want, but I doubt they will form because of those lines you just drew.
Old May 29, 2008 | 10:29 AM
neat's Avatar
Car: 1991 Corvette
Thanks!
Old May 29, 2008 | 11:34 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
He needs to stick with the '727 or half of his dash won't work. His vette has a CCM which talks to the ECM (and masters on the ALDL comm), not to mention his DIC won't work anymore. His "sys" light will flash forever driving him nuts.
-- Joe
J-money
Jan 4, 2019 09:45 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
