DIY WB-o2 sensor replacement
Old Jun 10, 2008 | 10:53 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Looks like it finally happened. My L1H1 sensor died after abt 30K miles.
At least I think it died. It was working normally, as I was cruising down the highway, then next time I glanced over the voltmeter was reading 2.503v and no longer moving. Voltage hasn't moved since.
Anyone know where I can get another?
After searching the forum, I'm still not positive a L2H2 or L3H3 will work.
If so, I've found a Honda part# 36531-RCA-A01 (L2H2) for a decent price.
It shows to fit a 05 Honda Odyssey V6 3.5L.
I remember there was a lot of discussion abt these sensors a while back, but I'm not sure it was ever resolved.
Any help would be appreciated.
Thx!
Old Jun 11, 2008 | 11:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: DIY WB-o2 sensor replacement
The L2H2 is the same sensor as the L1H1. The differences are in the wire colors, length, lack of grommet and the calibration resistor. To use the L2H2 don't use the supplied CalR.
Use either a pot or a fixed resistor in it's place. To find the correct value will need to free air calibrate for the proper Vout in air.
RBob.
Old Jun 11, 2008 | 11:21 AM
Ronny's Avatar
I ordered replacement from Rock Auto. The part # is on the Innovate forum. I believe it was a VW mfg or Honda.
Old Jun 11, 2008 | 01:41 PM
Doctor J's Avatar
Rock Auto shows:
BOSCH Part # 15401 {Wideband A/F Sensor}
Rear; 5 Wire; Wideband A/F; Check / Replace Interval: 100,000 Miles; OE Type - Upstream
for an 05 Odyssey; priced a little over $100. Does that seem right? Anyone have a part number for the matching electrical connector?
My L1H1 still runs, but I was thinking it's been in use for quite a few years now...
TIA
DRJ
Old Jun 11, 2008 | 02:03 PM
Ronny's Avatar
I believe the part # serves many vehicles. On the Innovate site and their forum they list the part # Bosch. I was told by Innovate that the life of sensor is dependent on where it is located and also start up procedure. Mine is ign on-sensor heat on. fuel pump off- sensor off. starter on- sensor off. car runs -sensor on. So no voltage spikes to controller and no moisture on hot sensor. that kills it very soon. Also they suggested I move sensor back farther in ext stream as I had it at header collector flange.
Old Jun 11, 2008 | 09:46 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Just what I needed to know. Thx guys..
bamaboy0323
Sep 3, 2015 06:07 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
