IS D.F.C.O. ,, OFF ??????
Car: 1982,Z/28
Engine: 355
Transmission: t350
Ive been logging my blm and setting now with my dfco off [i hope] and setting my ve tables.--- But i get the feeling my dfco isnt off, I was told to max out my dfco rpm min and max., and that should do it.---IF if it was off would you see a super lean condition when you let off gas ? [ wide ban reads top of screen] - IM using tuner pro and 7747 ecm.
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Car: 1982,Z/28
Engine: 355
Transmission: t350
Re: IS D.F.C.O. ,, OFF ??????
so if mine goes to max lean ,, when i let off gas then dfco is still not off when i let off gas. -- ive max out rpm min/max,, I wonder if maybe i have to do something with the map setting now ??
Car: 1982,Z/28
Engine: 355
Transmission: t350
I guess there is know way of turning D,F,C,O --Off ??? tried everything i can think of. - any ides would be great
Car: check
Engine: check
Transmission: check
Just set the CTS enable temperature high:
LD2F2: FCB 128 ; DISABLE DECEL FUEL Cut Off BELOW 75 c
°C = (N * 0.625) - 5
RBob.
RBob.
I see on WB 14.7 on steady cruise and on foot off gas it goes rich as the sticktion of gas is pulled off the venturi/intake surfaces and enriches in log for a short while. Then I see that very lean spike. Now I run non DE(turned off/disabled) and I still see that result in log as fueling is now running off say 20 MAP at 3000 rpms fueling as an example .
Car: 1982,Z/28
Engine: 355
Transmission: t350
yea, rbob, I POSTED late last summer on this and you told me what to do but i cant find thos you mention ??. --My tune is based off the ASDZ BIN and i use XDF FILE,,, 7747- MINE XDF ---Is there another xdf file i may need ???
Car: 1982,Z/28
Engine: 355
Transmission: t350
I guess ill have too search some where else for a possable answer as to why i dont have thos settings [adress] in my bin to turn dfco off,, ??
