EBL Com Port ?
Old Jun 25, 2008 | 12:12 PM
Ronny's Avatar
EBL Com Port ?
My laptop has 2 USB ports one set to 6 other set to 7. In EBL I used to use top USB port which is set to 6 and I set EBL to CP6. Now I see EBL shows com 6 "locked"? So now I can only use the other USB port set to7 - EBL set 7.
How to unlock EBL CP 6?
Old Jun 25, 2008 | 01:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Com Port ?
With the WUD version 2.1g the Com Port will be either 'Open' or 'Closed.' This is shown on the main displays in the upper left corner under 'Port: COMx", the x being the selected port.
Any message that states 'locked' is not from the WUD.
With WUD versions prior to 2.1g when the selected port can't be opened, a popup with the message "Can not open COM Port" with the title of "Port Selection Error" is given.
RBob.
Old Jun 25, 2008 | 02:22 PM
Ronny's Avatar
Re: EBL Com Port ?
As I stated earlier I am having logging sessions suddenly stop. I believe it is a "connection" issue at the USB port. either the male USB on adapter or the port on lappy is an issue. Depending how I route the cable around laptop will help the problem.
This happenned when I was trying to set up a VELearn not during a logging session. Seems made several changes in .bin selection that it did not like.
Is there a setting that will unlock a com port on lappy? USB Root Hub showed enabled?
Old Jun 26, 2008 | 06:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Com Port ?
Some USB drivers have a utility that can be used to set up the port. You may be able to use it to assign which port gets used. Usually you can plug into either physical port and the driver will see the cable.
There may be some dirt in either or both the cable and laptop connectors. It doesn't take much to prevent contact.
RBob.
Old Sep 24, 2008 | 12:08 AM
shanes383tpi's Avatar
Car: All go and no show!!!!
Engine: 383 AFR 195s First Manifold
Axle/Gears: corperate 9 1/2 14 bolt 4:11
Re: EBL Com Port ?
Don't mean to resurrect an old post "but" one more question concerning same topic. I am using the EBL also. With a radio shack usb to serial adapter. During use I have to continually reassign com port 9 in WUD to continue live updating (data logging & VE learn). Am I doing something wrong or is the radio shack adapter to blame. PS all cables are new and clean. Thanks for any help offered.
Couldn't sleep noticed RBob answered this question back in 2006. Going to sleep will be easy now think I read every post on TGO
Shane
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
