where can i get this bin? i want it to be a 95 truck, with BBC tbi, and 60e tranny.. i need to compare AE vs TPs and AE vs Map from a BBC throttle body. and also i want to compare VE tables how they are populated.
im think about starting my tune over and using a BBC bin. i keep hiting walls no matter what i do @ 2-3k rpm. im thinking about just getting it dyno tuned again, if not a carb will do. i should be able to WOT then..
I think the best place to look is craig moates website under "file downloads".
http://www.moates.net/
i have look their b4, what file and name do i need? maybe thats my question.Originally Posted by Ronny
I think the best place to look is craig moates website under "file downloads".http://www.moates.net/
I doubt you will find a BBC truck with a 4L60E. They would have the 4L80E tranny. It appears that BMHM is the only 7.4l auto BIN for the '7427 PCM.
I believe that the '7060 PCM was used more for the BBC w/4L80E tranny. That would be the $85 MaskID. BAMW would be one BCC for it.
RBob.
RBob.
RBob.
you know i couldnt find those bins, on moates.net/fileman Originally Posted by RBob
I doubt you will find a BBC truck with a 4L60E. They would have the 4L80E tranny. It appears that BMHM is the only 7.4l auto BIN for the '7427 PCM. I believe that the '7060 PCM was used more for the BBC w/4L80E tranny. That would be the $85 MaskID. BAMW would be one BCC for it.
RBob.
but anyways, i looked in the tune, and where the wall occurs, is where around 2-2400 rpm, and at async - sync it switches at 2100 rpm..
but i dont really know how to setup my bin to make the bbc inj work properly. cause i also know its other settings similar. i think this is my problem. but do i want to be in async or sync? and how do i set this up.
also im runing at 30 psii now. still hit that walls in the range at times, and its running BEST ever, i mean it was like a sports car. just the wall happens at times.
my injs are 90# @ 30 psi. i can upload my bin, if i knew how to.
