What RPM limit on my 383 build...
Old Jul 19, 2008 | 04:24 PM
dan_t's Avatar
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
I'm wondering what would be a good compromise on RPM limit of my new build... I'm using an auto and going to keep that at stock shifting points for now ~ 4,700rpm but I want to know what I can hold it too.
Scat 9000 Cast Crank
Scat I Forged I Beam Rods
Claimer Hyper Pistons
Clevite Bearings throughout
The car starts really pulling around 3,000rpm.... I beleive it would make power up to around 6,800rpm but I think that pushing things a little
LT1 Intake, AFR195 Heads, Rollertip Rockers, CC306 - 230/244 .544/.576
Thanks in advance
Old Jul 25, 2008 | 05:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: What RPM limit on my 383 build...
Keep it a hundred or two under what your valve springs can handle. I believe your stock AFR springs are good for 6K.
I have the AFR Eliminators and have my max rpm point set to 5900.
Typically I let the car shift itself but it's nice to know that I have more power available to me if I need it.
Old Jul 25, 2008 | 06:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
depends, if you have the 8017 springs i think they are more than enough spring for the cc306. that cam should peak by 6000-6200 and be good to 6500rpm. Its not much different from my custom grind to be honest. I'd probly shift by 6400 with that combo. I take mine to 6500 but i'm not sure where the power stops
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
