Idle "hunts" when a/c turned on?
Old Aug 3, 2008 | 01:44 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Greetings folks,
I'm using s_aujpv4, and I my normal idle is pretty much stable. What's odd is that when I turn on the aircon, the idle starts oscillating...about 300-400 rpm...any ideas?
Old Aug 3, 2008 | 01:47 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: Idle "hunts" when a/c turned on?
try richening up the idle a little.
Old Aug 3, 2008 | 03:40 PM
Axle/Gears: 4.1
It's already commanded to add 12.5 rpm
...when the a/c is turned on. I was hoping someone would know why it would start hunting just because the a/c came on.
Could there some sort of oddball occurrance developing as the 12.5 rpm are added? Such that the rpm would start hunting?
I'm reluctant to just making it richer at idle because it idles quite well without the a/c on.
Old Aug 3, 2008 | 05:10 PM
Gary Anderson's Avatar
Does the MAP increase with the A/C on? Likely it does and that is the area that needs a little more fuel.
Old Aug 3, 2008 | 06:42 PM
Axle/Gears: 4.1
Ok, good enough, I'll compare the....
MAP at those points, a/c on vs. a/c off, and see what's happening.
Thanks all...
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
