LC-1 controller mounting
Old Aug 9, 2008 | 07:53 AM
bonesbrakr's Avatar
Will be installing a LC-1 soon and was wondering where everyone mounted the controller. My thought was to drill a 1 1/4 inch hole in the firewall around the area of the gas pedal. Get a body plug the same size to put the wire into and wire it that way. This way the unit is not subject to road debris and is kept away from heat and safe. Thoughts and suggestions are welcomed.
Bill
Old Aug 9, 2008 | 11:45 AM
90c350's Avatar
Re: LC-1 controller mounting
I mounted mine in the engine compartment on the Passenger side Fender right near the firewall. This is on a P.U though. Have had no problems with it there.
Old Aug 11, 2008 | 02:53 PM
???'s Avatar
mine is zip tied to the cross member. been that way almost a year and is fine.
Old Aug 11, 2008 | 03:01 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Mine is mounted right behind the passenger side kick panel.
Old Aug 12, 2008 | 02:23 PM
Ronny's Avatar
Mine is happy in the storage area behind the shifter(Vette). A DB32 A/F gauge sits on the pillar. Initially I had the sensor in ext pipe directly behind collector. Sensor failure resulted. Innovate suggested moving it back a bit. It ended up about 20 inches further back right behind passanger seat where the storage bins are located. Excess cable resides there and a .75 hole with gommet and silicone sealer makes for good seal.
Old Aug 18, 2008 | 11:29 PM
88Stepside's Avatar
Zip tied to crossmember also. Going on three years, back of crossmember it's well sheltered from road debris.
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
