lean in closed loop
Old Aug 30, 2008 | 04:55 PM
brandenbtl16's Avatar
Car: 1951 Ford
Engine: Chevy 400 SB TPI
Axle/Gears: Ford 9 inch 373 gears
lean in closed loop
My car just started acting up. When in open loop the integrater and the blm are both at 128 and the car runs great. When the car goes into closed loop the integrater jumps up to 180 and the blm goes to max i believe 160. This is puzzling because the car smells very rich when this happens???? also the car started to surge at stop lights now when this problem happened. any ideas by anyone???? There are no codes on my snap on scanner???
Old Aug 31, 2008 | 08:53 AM
the blur's Avatar
Re: lean in closed loop
so it's actually very rich, but the ECM is seeing it as running lean. This seems to be very common on the corvette forum when people switch to new injectors. It's as if the O2 sensor is not reading correctly.
my car does it at idle, but not as bad as yours. mine goes to 159 BLM's. but the intergator stays reasonable.
I havn't played with it much recently.
Old Aug 31, 2008 | 09:06 AM
Car: 1951 Ford
could i have a bad o2 sensor? Like i said i haven't changed anything it just started doing it??
Old Aug 31, 2008 | 09:50 AM
Car: 1951 Ford
nevermind vaccum leak all better
Old Aug 31, 2008 | 05:03 PM
the blur's Avatar
where was your vacuum leak?
Linson
Oct 24, 2025 02:00 PM
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
