WHAT CHIP DO I NEED TO BUY TO REPLACE THE STOCK ONE WITH
Old Sep 2, 2008 | 04:06 PM
blueridge23's Avatar
I HAVE A 1991 Z28 W L98 MOTOR?
I AM GETTING THE CHIP BURNER AND CABLE JUST
DON'T KNOW WHICH CHIP TO BUY
Old Sep 2, 2008 | 04:13 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: WHAT CHIP DO I NEED TO BUY TO REPLACE THE STOCK ONE WITH
your post is so non specific and random. Do a search for the memcal that came with L98's of the year you're trying to use. Then you'll atleast have the code you need and be able to search for source.
Old Sep 2, 2008 | 04:25 PM
i DID THAT AND I GOT 1227730
IM USING BURN1 Flash-n-Burn USB-Based Chip Programmer
NOT SURE WHICH BLANK CHIP TO BUY FOR 1991 L98 CAMARO.
SOMEONE PLEASE HELP
Old Sep 2, 2008 | 04:37 PM
18436572's Avatar
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Axle/Gears: 4.88 full spool
I do not use the BURN 1, I use the pocket programmer for burning my chips. I use 27c256 but that chip requires a UV eraser. The 27c256 should work if you have a UV eraser.
Old Sep 2, 2008 | 04:46 PM
18436572's Avatar
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Maybe try a AT29C256 if you do not have a UV eraser.
Old Sep 2, 2008 | 04:51 PM
HOW DO I KNOW IF I HAVE A UV ERASER SORRY VERY NEW TO THIS
Old Sep 2, 2008 | 04:54 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I suggest you start here: https://www.thirdgen.org/forums/diy-...uide-book.html
Oh and BTW, there is a button above your left shift key, press it once. The key will have "CapsLk" or something similar on it.
Old Sep 2, 2008 | 06:14 PM
AC's Avatar
AC
blueridge, sorry bout my first post. Your original post didn't include the info. The others have given you good info. I used the same chips in the past but have since replaced burning chips with a real time emulator and upload/download to that.
Old Sep 2, 2008 | 06:42 PM
convas's Avatar
I use these, you wont need and UV eraser the BURN1 can erase them.
http://www.moates.net/product_info.p...products_id=39
italiano67
Dec 11, 2016 09:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
marcusaw
Aug 10, 2015 08:13 AM
Exxon Limited
Aug 9, 2015 08:13 PM
