'91 3.1 question
Old Sep 26, 2008 | 11:29 PM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
'91 3.1 question
So I just started trying to get into this and I've run into a slight issue, here's where I'm at. I can copy the factory chip and burn a new one and it runs just as good as the factory one. I have the definition from tunercats ($88 for the LHO engine) and the factory tune reads in there as it should. When I change anything even if it is just to re-enter a factory setting (so should be no change other than being edited by the program) then burn it to a chip and install it in the car, the car won't idle and the coolant fan won't turn on. Am I doing something wrong or missing something like in settings or something?
Old Sep 27, 2008 | 09:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: '91 3.1 question
Sounds like something in the burner settings. Compare the edited BIN to the stock BIN and see if they are the same. Then move on to checking the burner setup parameters (buffer and PROM affsets and such).
RBob.
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
