OD mask way fat on decel?
82 Camaro. 5.7, 4L60e. Transplanted from 94 truck. Stock except for 305 TPI heads and port matching with heads, intake. Short tube headers. EGR disabled because of sticking EGR valve, probably will replace and enable later. Problem is its fat on decel. Max BLM and integrator still wanting to add more fuel. Surges on decel. Ran my enlean % to 100 in small steps and no change. Thought it may be stall saver so I went the other way also with no change. Also advanced spark which helped bring down integrator in upper RPM's but has not solved problem. Any ideas?
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
Re: OD mask way fat on decel?
If the EGR valve was sticking and you disabled it , did you fix the leak ?
Mongoose462ci
Sep 16, 2015 11:46 PM
