Thinking of switching from a E6 to a 0D
So I have a really good tune right now in my truck using the stock E6 Mask. the issue is I cannot find a ADL file that matches for datalogging. How can I convert and keep my tune. I am using tunrerpro for datalogging. I am able to datalog with Datamaster with no problem just cannot seem to find a good def file for tuner pro.
Transmission: 5-speed/T-5
Re: Thinking of switching from a E6 to a 0D
You can make an ADS file, from the ALDL datastream information found in the files on moates.net file uploads and downloads section.
Actually thats what I wold like to do but need sombody to point me in the right direction. I have a good bin I have a good XDF file. How would I go about making my own ADS file. I have one that is supposed to work but does not. How do I map the values such as Coolant (F) degrees I am just trying to get a reference point. add one value make sure it works then add another and so on.
I posted information on how to do this for the 160 baud datastream with Scanner Pro on the Tuner Pro forum, TP RT is similar. Location and file names I posted in that thread.
I will take a wonder over there and take a look. I am still fighting packet errors right now so I have to get that figured out. May I bother you with some questions if I get stuck ?
thank you
thank you
If I can help, I will. I'm still a long ways off of being able to fully understand the language used, but it's slowly starting to make more sence the more I play with.
ECM test bench has been instrumental in starting to understand more about how the ECM works.
There are other people here that know this stuff better than I do, and could likely provide better help.
Ghettobird52
Jul 5, 2024 11:18 PM
