AE and PE? In depth explanation?
Old Dec 29, 2008 | 12:31 AM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
I understand that PE basically kicks in at a certain % TPS, but what exactly does it do when it kicks in?
And AE basically controls how much fuel is injected when you press the gas to accelerate?
Can someone give me an in-depth explanation of both of these, including:
-What exactly they control?
-Best way to tune them?
-What happens when they engage?
I remember reading that when tuning your car, that setting the PE (%tps) really high so it never engages, but when you are ready to tune the PE, turn it back to stock settings and tune it AFTER everything else has been tuned. is this correct?
thanks
Old Dec 29, 2008 | 12:42 AM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: AE and PE? In depth explanation?
read the prom tuning guide in the stickies in the DIY PROM it will have your answers I re-read it many times and almost always find help
Old Dec 29, 2008 | 03:26 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
The stickies are a great help
Old Dec 29, 2008 | 03:32 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
PE adds more fuel and spark when engaged.
-not sure what they control other than fuel and spark
-best if used in moderation
Old Dec 30, 2008 | 11:11 AM
Ronny's Avatar
I asked thet Q about a month or two ago. Rbob provided the details.
PE I understand offers a commanded A/F based upon RPM and utilizes last seen BLM when ever the TPS attains that value set in bin(40%-50%-60%). If BLM is adding fuel it uses that. If removing fuel it uses 128. Safety.
AE I understand occurs when the TPS% change is attained over a set period of time. Volume and duration can be set in bin. Same on change in MAP. AE-TPS is the predominant provider of enrichment. MAP is a filler. AE MAP can occur with no change in TPS. Trick Q how can that happen? Simplistic answers I gave. Search for RBobs answer to my question. It was in a thead started by another poster.
Old Dec 30, 2008 | 07:14 PM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
How are ae and pe affected if the ecm is left in open loop at all times? I will be disabling closed loop for tuning and do not plan to put it back into closed loop. I am doing this because I will be using a wb02 for tuning all aspects of the ve table including idle, part throttle, and wot
Old Jan 2, 2009 | 02:03 PM
Ronny's Avatar
I ran OL for a season off and on. Result was gas mileage went in toilet. Mostly due to air temps in Wis can vary greatly day to day and same from early AM to PM. I dont believe there is any change in AE-PE from OL operation. I will guess it still looks at BLM data even though not used to correct A/F.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dimented24x7
Sep 17, 2015 06:58 AM
88 427 Camaro
Mar 20, 2001 06:39 AM
89BlwnRs
Nov 12, 2000 03:47 PM
