454 IAC steps on an '8746 ECM
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I'll be running an '8746 ECM with a 454 throttle body.
It seems that the 454 IAC has different steps than the 305/350 IAC. I know others have used 454 IAC's with this ECM, how did y'all recalculate the steps for the IAC? Does anybody maybe have a TunerPro/TunerCAT table that they'd be willing to share?
Lou
Lou
Engine: TPI
Re: 454 IAC steps on an '8746 ECM
What did you use for the following constants?
IAC - Park position steps
IAC - Steps added to low BatV
IAC - Max steps added low BatV
IAC - Max throttle follower steps
IAC - Max steps
Lou
IAC - Max steps
Lou
I am at office so will have to inspect bin when I get home. I have manual trans. I will guess however!
Park zero steps or use stock bin values reduced 40%
low batt maybe 5 additional or as above
" max I dont know or use stock bin as above.
max throttle follower maybe 2 steps or stock as above
Iac max 70-80 or so.
I never had issues with stall on cold start. So I prefer a low idle rpm on cold start. same on restart warm engine. when engine starts it goes right to idle speed with no flare up in rpm.
Engine: TPI
Alright, thank you for the answers.
I pulled what I could from the ANTY bin (454ci with '7747) but I'll have to play it by ear when I'm ready to start the beast up.
The low-rpm startup is a good idea, I'll have to try that, now that I know (from you) that it works fine.
Lou
Lou
When I first added IAC control on thr 7.4L TB I had stock .bin settings. Cold start the car roared in driveway at 2000 rpms(duals with hooker aerochambers). Not good for condo neighbors. I ended up dropping it 20 steps at a time till I found what I liked. I was also able to adjust the deacy rate so hang time was diminished on warm start(>160 d F).
