Free air calibration ZT-2
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Is there one? I can't find any reference to it in my paperwork but apparently the Innovative ones have it.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Free air calibration ZT-2
the ZT2 doesn't require or use a free air calibration.
its part of the reason i went with the ZT2 instead of the Innovate.
i was worried that the ZT2 may not read as accurately as the Innovate, but after having used mine non stop for well over a year, it still checks out with the 5 gas analyzer at work.
Car: check
Engine: check
Transmission: check
The problem with free-air calibration on a WB is that it only calibrates the lean side of the sensor. It is OK for a 'sanity check' of the sensor, but does fall short of a full sensor checkout.
IOW, if the free air check is OK, it doesn't mean that the sensor is OK on the rich side. But if the free-air check shows an issue, then there is a problem with the sensor (or electronics).
RBob.
RBob.
1992rs/ss
Jan 31, 2025 05:10 PM
