No engine start 6E def ARAP Bin
Old Feb 25, 2009 | 04:18 PM
hotrodta57's Avatar
Car: 1988 T/A
Engine: L98 Highly modified
Transmission: TCI 700R4
Just installed my Prominator and uploaded the ARAP bin with the only change being 22lb injectors to 30lb injectors. Upload was successful both from verification of Prominator program and cooling fans shut off. Cranked the engine and acted like it wanted to start for a couple of seconds then like no spark.
Old Feb 27, 2009 | 05:25 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Re: No engine start 6E def ARAP Bin
Disable VATS in the bin? Also, check out the Ref Pulse vs. PW table. For some reason GM set the first 8 values to 0. I changed these to .50, and motor fires nearly instantly.
Old Feb 27, 2009 | 06:43 PM
hotrodta57's Avatar
Car: 1988 T/A
Disabling VATS did the trick! Will also check the values you mentioned. Starts easily, but runs bad now. Time get to work. Thank you for the help!
Old Feb 27, 2009 | 06:54 PM
hotrodta57's Avatar
Car: 1988 T/A
Thanks again S105.7,
You were correct they were indeed set to 0.00. Changed them as you suggested. Will try again in the morning losing my light. Thanks for the help.
Old Feb 28, 2009 | 12:05 AM
S105.7's Avatar
Engine: L98 & L03
No prob, just passing along what I learned here.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
beast94
Aug 20, 2015 06:44 AM
