what do i need? tpi..5.0 -> 5.7
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
can i use my stock 305/chip/comp for a 350 swap with just a few bolt ons
i plan on upping the fuel pressure with stock 19lb injectors
but idk if it will run smooth
it is on an 89 MAF bird
is there anything else i should change?
thx bill
thx bill
Car: check
Engine: check
Transmission: check
Re: what do i need? tpi..5.0 -> 5.7
However, if you use the 305 injectors with the 350, then using the 305 calibration will give the best results. But at the same time will run lean at the top end (out of fuel).
The reason for this (apparent) inconsistency is that the MAF calibrations only have an injector flow constant. There isn't a displacement constant. So a 305 calibration is set up for 19#/hr injectors. Which will work with various displacements.
If you put a 350 calibration in the engine will always run lean. If you put a set of 350 injectors in with the 305 calibration it will always run rich.
Took the long way to get here, but you should put the proper injectors in along with doing a proper calibration (tuning!!!).
RBob.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
you are better of using a set of 22lb or even a set of Lt124s with the 19s you will be way over the duty cycle
Car: 89 Formy
Transmission: A4
ok good...so i should get a stock l98 computer chip?...or the whole computer itself for a MAF 350
Car: '88 Trans Am
Engine: 5.7L TPI
you should get a 350 chip for sure if you can get a computer w/ 350 chip definately go for it. if you need Lt1 inj. i have a set off my Lt1 for 30.00 shipped
Car: check
Engine: check
Transmission: check
blackz281le
Jan 11, 2016 07:51 AM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
