PROM compatability
Old Mar 2, 2009 | 02:51 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
PROM compatability
Hello maybe this is the right place to ask this question???
I have a stock 89 5.7 TPI PROM (AUJM). Can I use this in an 87 ECM (165 style)? Will I still have to worry about VATS functioning?
Thanks for the help.
Old Mar 3, 2009 | 10:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: PROM compatability
The '86 through '89 TPI systems use the same '7165 ECM. So that chip/MEMCAL will work in any of them. VATs will still work with the '89 chip. So if used in a pre '89 tpi f-body the engine won't start.
RBob.
Old Mar 3, 2009 | 09:10 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Thanks RBob. I that's what I needed to know. I will pick up a new ECM.
Also, do you know of a good inexpensive chip burner that can remove VATS and lower my fan turn-on? I've heard of fastchips, but if someone around this board does it, I'd rather put my money there.
Old Mar 4, 2009 | 08:40 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Moates.net will have a good burner, and pick up a copy of tunerpro rt while you are there.
Read the threads on tuning, and you'll be on your way.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
