1228746 for TPI setup
Old Mar 6, 2009 | 06:30 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Propably this question is a bit silly but i'll never know if i won't ask.
I run 383 HSR on '165, i want switch to '730 but it is hard to find this ECM in Poland, my friend just gave me this 1228746 ECM which is 350 TBI SD and i was wondering if is it possible to use with MPFI setup ??
Old Mar 7, 2009 | 07:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1228746 for TPI setup
You would be better off with the '7165 over a stock '8746 ECM. If you want to move to a speed density setup there are a couple of options. There is the Aussie '808 code that will run in the '165, or can keep looking for a '7730 (maybe purchase one from someone in the US?).
The main issue with the '8746 is that the injector firing rate will be twice what it should be for MPFI. Secondary issues are smaller tables, which compromises the tune over what a '165 or '7730 (masks $32, $6E or $8D) provide. Although there is a fix for these issues.
RBob.
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
