High Fuel Pressure
Old May 2, 2009 | 08:13 PM
hotrodta57's Avatar
Car: 1988 T/A
Engine: L98 Highly modified
Transmission: TCI 700R4
High Fuel Pressure
I have an Accel AFPR with the adjustment screw turned completely out yet my pressure is at 50psi with vac disconnected and 43psi connected. Any ideas as to why? I believe it should be at 36psi.
Old May 2, 2009 | 10:21 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: High Fuel Pressure
Probably a bad. or weak pressure spring in the regulator, or insufficient vacuum.
Old May 6, 2009 | 07:32 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I beg to differ 7# is about right for the vacuum change, and the more you screw in the bolt the more spring and fuel pressure. The spring is too long/too strong with bolt backed out.
I would check that the bolt is fully retracting and then shorten the spring by an amount less then the extended bolt (all the way in).
Old May 7, 2009 | 10:08 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Correct; excuse my dyslexia.
Old May 8, 2009 | 06:37 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
It will be my turn tomorrow.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
