Would I benefit from a custom prom?
Old May 11, 2009 | 08:45 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I have a very mild budget build in my Iroc currently running off the stock 305 auto chip, it's a 4 bolt 1 piece rms truck block with world products s/r torquers, a 96 y-body lt1 cam, home ported factory tpi setup with a bbk AFPR set to 45 psi w/o vaccum and 22lb injectors (and an airfoil that was installed in the tb when I got the car ) Compression is about 9.5:1, like I said it was an extremely low budget build using stuff I already had, not trying to build a drag car or anything. Behind it is a 700r4 with the factory converter and a transgo kit, exhaust system is completely factory until I get money for headers and a catback. It seems to run just fine with the factory chip in place but I was wondering if I should just find a factory L98 prom and call it done or if I should look into a custom burnt prom. With a setup this close to stock would it even be worth it?
Old May 11, 2009 | 11:00 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Would I benefit from a custom prom?
Even stock combination can benefit from a custom tune.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
