Prom ID ?
Car: Revcon Motorhome ECM:16197427 BJKW
Engine: 502 HT W/MPFI, Thorleys, Magnaflows
Transmission: 4L80E
Axle/Gears: 3.53 + Transfercase 1.11
Prom ID ?
Ok this is probably a stupid question, but what is the prom ID and why can't I set it? Since I'm running 8 different programs on one chip, I thought I could easily ID which program I'm on when I data log, but I can't seem to change the prom ID. If that is not changeable, is there anything other location I can just arbitrarily set?
Car: check
Engine: check
Transmission: check
Re: Prom ID ?
The PROM ID can be set to any value from 0 through 65535. The location will need to be in the ECU/XDF/TDF file, and what ever scan tool you are using also needs to be aware of it.
RBob.
RBob.
