Another Wideband with 6E ?
Old Jun 7, 2009 | 08:20 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I'd like to run a signal from my wideband to my AutoPROM. Is it possible to use the same method as SD using channels 1,2, or 3?
Also how do you guys route your wiring? I'd like to leave it as a permanent install.
Last question for now. I have an X-pipe on my Monte. Would it be a good idea to place the sensor in the X or just mount it to the pass. side collector?
Thanks for all the info you guys have offered and helped me get back on track with my car. I was ready to burn it a while back. Here's a video of the cold idle I took today:
http://www.youtube.com/watch?v=SdBuNwlQtHE
Old Jun 7, 2009 | 10:25 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Another Wideband with 6E ?
should be able to use the extra channels.
Here is a post I made when I first investigated it.
The trick was to use the 10 bit conversion but still have the 16 bit setting.
http://forum.tunerpro.net/viewtopic.php?t=396
Old Jun 9, 2009 | 07:01 PM
Duts87ss's Avatar
I'll have to give those a go when I get the bung installed.
Anyone have any suggestion on bung placement?
Old Jun 9, 2009 | 07:59 PM
JP86SS's Avatar
I really wanted to put mine in the X but the LC-1 length wouldn't reach.
Its in the collector now (drivers side) but is "pulsy" if that is a word.
Going back a bit would smooth readings for sure.
Azrael91966669
25
Jun 20, 2017 04:04 AM
efiguy
Sep 27, 2015 01:30 PM
tuningnewb
Sep 23, 2015 07:06 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
TRAXION
62
Jul 31, 2007 08:28 PM
