$61 bin cooling fan issue
Old Jun 29, 2009 | 12:25 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I've been driving this car and it begins to get hot with a/c on, city driving. On the highway, it stays cool. I'm going to give the car a flush, replace the single fan and wanted to replace the thermostat with a 160. Was looking at the $61 and couldn't find where to kick the fans on earlier. Am I using the wrong bin?
Old Jun 29, 2009 | 03:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $61 bin cooling fan issue
The '8746 $61 mask doesn't control the fan.
There is a switch in the passenger head between 6 & 8. Along with the A/C pressure switch. Can replace the head switch with one from an '87 Buick GN. It turns on at a lower temperature.
Couple of things to check: make sure that the air dam is intact. Remove upper radiator mount and check area between A/C condenser and radiator. That area usually fills with road debris which cuts off the flow of air.
RBob.
Old Jun 29, 2009 | 04:05 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
RBob.
Holy hot air batman! I didn't know that. Will take off radiator mount, its a bit hot outside right now. Will replace switch too.
Thanks!
Old Mar 28, 2018 | 05:19 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Those fan switches are really easy to snap off at the bolt face if you're not careful
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
dyeager535
Aug 28, 2015 08:10 AM
beast94
Aug 20, 2015 06:44 AM
Leggman1
Aug 6, 2015 04:15 AM
