ostrich help
Old Jul 11, 2009 | 12:35 AM
onesweet92z's Avatar
Car: 92 camaro z28
Engine: 355 tpi
Transmission: t-5
Axle/Gears: 373
ostrich help
just wondering what im doin wrong i got the ostrich 2 and plug it in and load the stock bin but car wont even stay at an idle let alone run long whats wrong
Old Jul 11, 2009 | 12:46 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: ostrich help
Well being that an ostrich is a flightless bird of course it doesn't make any power. Try an eagle or a falcon.. I got a 2.8 pigeon and it does the job...
Old Jul 11, 2009 | 08:05 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: ostrich help
When you say "load the stock bin", do you mean you open it in the program, or actually upload it to the Ostrich?
If you are using Tuner Pro RT (you didn't specify the program), you need to "initialize the hardware" (should do this automatically at program start, or click on the what looks like computer cable icon in the tool bar), once it shows Ostrich 2.0 connected in a low left hand box, click on the "up" arrow also in the tool bar, this will upload the bin to the Ostrich.
Check for proper CEL operation at start up. Should flash on, off, back on again, until the car starts. If it just turns on with th ekey and never shuts off, you're in Limp Home Mode.
Check that the EMU cable is properly oriented. If you are using a '7730/'7749/'7727 style ECM, then the red line should be towards the end of the MEMCAL adaptor. If you are using a '7747 style ECM, the red line should be towards the CAL PAK, and you will also need a Socket Booster 1.0 for this application.
Old Jul 12, 2009 | 01:09 AM
Car: 92 camaro z28
Engine: 355 tpi
Transmission: t-5
Axle/Gears: 373
Re: ostrich help
yea im usin tuner pro and uploadin the stock bin moates gave me on a disk for my year and have clicked on the up arrow but the key wasnt on yet but it dinged and said it went or at least i thought
355tpipickup
Aug 19, 2015 10:02 PM
jeeps2creep
17
Feb 4, 2007 10:30 PM
Grumpy
Oct 19, 2005 12:09 AM
anesthes
Sep 21, 2005 09:36 AM
smokefan
Apr 29, 2005 11:58 AM
