Idle issues...kinda
Idle issues...kinda
Well it has been a while since I messed with the prom stuff. I have switched to a dfi setup, but I am working a 730 running on an old Blazer. I think I need a refresher...LOL!
Well here it is, I am running a 730 ecm with the AUJP code. The issue I am having is that the desired idle speed in Tunerpro RT does not match my idle RPM vs. temp. What am I missing? It is like the idle is referencing another table/strategy.
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Re: Idle issues...kinda
Is it high or low? Stall saver? IAC params? Idle spark/VE? Idle overspeed/undersped spark? There is so much it could be.
dfi? direct fuel injection?
Well it is following some table because in the Tunerpro RT the idle it is commanding to is lower then what I have in the idle vs. temp table. I have tried to look for other things that might change the commanded idle. It isn't a spark issue because it is hitting the idle that it is commanding.
DFI is Digital Fuel Injection
Car: check
Engine: check
Transmission: check
AUJP has a hardcoded idle speed limit. It is set to 800 RPM. So can't get it to idle higher then that.
RBob.
RBob.
