changes on burn not taking affect
Old Aug 31, 2009 | 08:51 PM
brandenbtl16's Avatar
Car: 1951 Ford
Engine: Chevy 400 SB TPI
Axle/Gears: Ford 9 inch 373 gears
Hello,
Car is running very rich. blm=108
no matter what changes I have made nothing happens so I pulled the entire e-prom out and the car still runs????
Is this even possible??? What is going on???
Why is the car not reading or running off the eprom and memcal??
Old Sep 1, 2009 | 10:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: changes on burn not taking affect
Without the PROM the ECM goes into limp mode and can still run the engine.
To check if the ECM is running from the PROM look for the SES blink:
At key-on, engine-off, the SES should, turn on briefly, blink off, then turn on solid. To repeat the test key-off for at least 10 seconds.
If the blink doesn't occur, the ECM is not running from the PROM.
The SES blink should be looked for after the insertion of every PROM.
RBob.
Old Sep 1, 2009 | 03:24 PM
Car: 1951 Ford
Ok I think the car is in Limp mode then because nothing I do on the MEMCAL makes any changes to the car and when you turn the key on.
The SES comes on then goes off but comes back on and blinks non stop....
Could I have a bad eprom?? bad computer???
The SES just blinks even when the car is running???
db057
Apr 28, 2019 07:45 AM
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
SG91camaro
Sep 5, 2015 10:27 PM
luvofjah
Sep 3, 2015 07:08 PM
