Need Help Please.
Need Help Please.
TunerPro RT with ostrich 2.0 on an 89 350 tpi procharged.
What .bin file and what xdf file should I be using on this 90 iroc 350 tpi ecu auto trans? Why can I not seem to find a correct .bin and .xdf file to use for this ecu? Do I use the 8d.xdf of moates/fileman/ and unkown .bin?
I get junk data when trying multiple .bins and .xdf files to match this ecu. I only have a wideband for datalogging purposes. I need a base setup to use so I can try and lean this out until I get the aldl datalogger. Any suggestions would be helpful.
I feel like such a newb here with tunerpro.
Car: check
Engine: check
Transmission: check
Re: Need Help Please.
It will all be $6E (this is the maskid).
Be sure to use an '89 BIN to start with. It is the only year that $6E was used. It would also be best to just read your stock EPROM and use that as the starting point.
Wait, I just did some re-reading. You installed a '90 TPI ECM?
In that case use the $8D stuff. Note that AUJP is the latest BCC for that set up.
RBob.
RBob.
Gunner242
Dec 25, 2015 04:49 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
