What proms needed
Old Dec 9, 2009 | 03:19 PM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
What proms needed
I have a 7730 speed density setup. My question is: What proms can be used to tune it. Does it have to be a AUJP. My setup is in a old camaro and is a standalone system. No A/C, trans hookups, or egr stuff.
Thanks in advance,
Justen
Old Dec 9, 2009 | 03:30 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: What proms needed
It doesn't have to be AUJP, that was just the most recent BCC for V8 TPI.
You can use S_AUJP, which is a modified version of AUJP.
If you are going to be running forced indution you can use code 59.
You could pull the bin off your existing EPROM and use that.
Old Dec 9, 2009 | 10:54 PM
Car: 1969 camaro
Engine: 90 TPI
No, what I mean is are there any proms I can use out of v-6 cars or other v-8s besides the 350 aujp chip to be able to erase and burn my program into for another chip.
Old Dec 10, 2009 | 10:57 AM
91RS_Charlotte's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.42 Std
You can't (or shouldn't) use a v-6 because the limp-home spark control won't work. Should be able to use any v-8 TPI, not sure if you can use a TBI. For instance, you could easily use an AXXB which is a 305 TPI SD Auto chip but would need to adjust for injector size, trans, etc...
Old Dec 10, 2009 | 03:52 PM
Car: 1969 camaro
Engine: 90 TPI
That is what I needed to know. I will reflash each prom I just needed to know what ones I could use. I had heard about the limp home in the v-6 ones.
Thanks. Now I got to find what chips where used. (ex. AUJP AXXB) and so forth.
One more, As Long as I reburn the whole chip will a 5sp chip work also?
Thanks,
Justen
Old Dec 10, 2009 | 08:33 PM
Car: 1991 Camaro RS
As far as I know, the Auto/Manual change is just one flag. I can't be sure as I used a file that matched my setup (AXXD - 305/5spd).
Old Dec 10, 2009 | 08:37 PM
Car: 1991 Camaro RS
One more thing - you may know this already, but the easy way to do this is to get a G1 adaptor from Moates (http://www.moates.net/product_info.p...products_id=32) $35. It passes through the ESC stuff and allows an easy method for inserting a burned chip. If you are going to tune or plan to swap chips more than a few times, you may want to consider a ZIF socket adaptor also.
Old Dec 10, 2009 | 08:59 PM
Car: 1991 Camaro RS
Wow - I need to thnk before I hit submit...
Anyway, here is a site with a list of codes for 1991 Firebirds. Should be helpful.
http://www.3rdgenformula.com/91/promcodes.htm
Also attaching as word doc in case the link goes dead at some point.
File Type: doc
Old Dec 10, 2009 | 11:27 PM
Car: 1969 camaro
Engine: 90 TPI
Thanks for both links.
The broadcast codes was what I needed. Thank you for your time and info.
Thanks,
Justen
Steven 86IROC-Z
May 24, 2026 04:52 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
