Can low coolant temp prevent ECM from PE mode?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If the coolant temp is 131*F, will this prevent the ECM from going into PE mode?
Car: '87 IROCZ
Engine: 395 ZZ4
Re: Can low coolant temp prevent ECM from PE mode?
The answer is that I still can not get the ECM into PE mode even with a coolant temp of 180*F. So I still have not figured out why the ECM will not go into PE mode even though the TPS is full open, TPS = 4.4V..
I really could use someones help here!!!!
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Are your constants for PE set correctly (for your setup)? I'm still learning; so, other than that, I have no other ideas.
Car: '87 IROCZ
Engine: 395 ZZ4
yes, I believe that they are, however, I will check them.
hydrolic144
Oct 4, 2015 08:23 PM
